oil coolers
Old Feb 17, 2008 | 06:12 PM
pig's Avatar
pig
Default oil coolers
im wanting to change to a 19 row oil cooler on my mk2 cossie escort,i dont really have the room in the front now tbh.what im wondering is can i use 2x13row coolers and use a t'piece then in to the sandwich plate?can anyone tell me if this will work and will it work properly and effectively.the reason im asking is i was thinking of putting 1 each side in the front of my rear arches on my x-pack kit.
Old Feb 17, 2008 | 06:28 PM
pig's Avatar
pig
someone must know,if in the wrong section sorry fell free to move mods
Old Feb 17, 2008 | 06:33 PM
RAT8OY's Avatar
RAT8OY
Dunno but that MK2 looks the dogs!
Cant see why you suggestion above would not work though! Surely the oil is just passing through, the more time its cooled on it route the better. I presume you sandwich plate is thermostatic? You dont want to be over cooling when you pottering about.
Old Feb 17, 2008 | 06:47 PM
pig's Avatar
pig
i never used a stat on it with just the 13 row cooler m8,but i will be getting2 new items if i know it will work ok tho,cheers for the coment on the car as well m8.ive added more pics in the old school thread bit
Old Feb 17, 2008 | 08:02 PM
pig's Avatar
pig
come on guys,there must be someone that knows if this is ok,please
Old Feb 17, 2008 | 08:53 PM
aurallis's Avatar
aurallis
it will prolly take forever to heat the oil up.So u fitting another /bigger cooler cos oil runs too hot at moe?if not then why
Old Feb 17, 2008 | 08:55 PM
JonnyBravo's Avatar
JonnyBravo
I would imagine you would need a extra pump to reliably pump the oil that far through the car.
It certainly sounds like a good enough reason to spend a few £££ on some aeroquip though
Brickhouse
14
Oct 3, 2015 07:28 PM
