ofab wiring plug. 7 wires.????
Old Feb 17, 2008 | 04:23 PM
ZVH,RST's Avatar
ZVH,RST
Default ofab wiring plug. 7 wires.????
i have got a fiesta turbo engine loom, ofab and want to add this loom to a mk4 escort rs turbo, so on the big plug there is seven wires,what wires go were,??ie. black.wire. ign live.?? brown,wire,? green/red wire. ?brownwire. ? black/green.wire. ? brown/green wire.oil light.??. red=live feed.??do i put a in line fuse in as well/??
Old Feb 17, 2008 | 07:10 PM
NATH-RSZT's Avatar
NATH-RSZT
right there is a very simple way to wire these in . its not the best way but the engine runs perfect.
Red wire , live
black wire live
black /green wire is this the fat one ifso also live.
brown , earth
now i cant rememeber off hand but i have it written in a book at work , but the other are simple rev counter , oil pressure , and fuel pump.
I know this way works as done many times before i never run the fuel pump from that plug i just run a live from the fusebox to the fuel pump.
I'll double check at work tommorow and update .
Hope this helps
Old Feb 17, 2008 | 09:04 PM
ZVH,RST's Avatar
ZVH,RST
please do as i want it right
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
