Saph boot badges
Hi
Is there any difference in the boot badges on a 2wd saph & a 4wd saph?
Im having my 4x4 painted & i want a new set of badges for it, i've got a chance to buy a set but the advert states 2wd 88-90.
Regards Matt
Regards Matt
2wd is SIERRA RS, as one metal piece and then seperate COSWORTH badge.
The FORD badge is different as well, the earlier 2wd FORD is a much lighter shade of blue, and ever so slightly smaller, you would not notice the size difference much but the blue is totally different.
Ford now only supply the later dark blue badges, as I was peed off I could not get a light blue earlier one for my2wd.
I just bought a set for my rear (badges went missing when painted ages ago), and I think I've been sold a mixed up set - the "Cosworth" badge is shorter than the "Sierra" badge, which is NOT what I see on other 4x4's which have it the same length. I presume I have a 2WD "Cosworth" badge perhaps? Is it shorter on a 2WD??
I also think the "Ford" badge I was given was too small, perhaps it's the one off the front grille?
