Anyone recognize this disc - 310mm??
Hi all,
I want to replace my discs as one is cracked. Trouble is that I have no idea what make it is? It takes a bell and the normal calipers are on extended brackets if that's any help?
Here are some pics - any ideas anyone??
Get on to Reyland or some one like that does after market brakes,you don't need to know who made the original ones
Just the size of discs/how many bolt holes/size between bolt holes etc and they will get them
Originally Posted by AndyPen
Hi all,
Looks like Hi SPEC, as said std disc with bell cut off, this is the way Hi SPEC do them, there are two MAIN sizes of PCD fitting for these, so very easy to make, if Hi SPEC, there will be on the edge of the bell a number, and also on the brackets, as these are stamped with the part numbers.
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
SMILER258
Sep 28, 2015 09:04 AM
