Yellow injectors bosch 0280150718???
Old Feb 16, 2008 | 05:11 PM
picky775's Avatar
picky775
Default Yellow injectors bosch 0280150718???
As above what power r they good for??? and would they fit a fiesta turbo efi?? many thanx
Old Feb 16, 2008 | 05:13 PM
Jasesapphy's Avatar
Jasesapphy
wrong impedence if there cossie yellows, you need high impedence
Old Feb 16, 2008 | 05:18 PM
picky775's Avatar
picky775
im runnin gotech management so should be able to run them shouldt i???
Old Feb 16, 2008 | 05:35 PM
Most but NOT all modern(aftermarket) ecu's will run either, some may require a resistor in the earth line to each injector.
Not all do this so just check.
Dan's Avatar
Dan
Max power on Cossie's is about 270ish bhp mate, Beiges are better of for FRST's are they not?
Old Feb 16, 2008 | 05:42 PM
The above injectors from a ford 5 litre V8 truck flow 199.7cc/mins, against 803's for comparison 389.9cc/mins
Old Feb 16, 2008 | 05:49 PM
picky775's Avatar
picky775
many thanks guys
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
