zvh oil cooler
Old Feb 16, 2008 | 05:04 PM
J690Turbo's Avatar
J690Turbo
Default zvh oil cooler
hi all having a bit of trouble today, fitted a 2 litre zvh in my s2, only when fitting the oil cooler its too close to the body work at the back of the engine bay and the oil filter will not fit, any ideas of wot i need to do
Old Feb 16, 2008 | 05:09 PM
adduk's Avatar
adduk
just had a look at mine and it doesnt have an oil cooler on it and i think mine got a different oil filter on it ,but im fitting a seperate oil cooler to mine.i think you leave the oil cooler off.maybe wrong and if i am someone will put us right.
Old Feb 16, 2008 | 05:11 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
most peeps dont bother, could use a smaller filter like of a 5 turbo or summet
Old Feb 16, 2008 | 05:13 PM
J690Turbo's Avatar
J690Turbo
ive got a oil filter for a 1.4 focus zetec, which i was told to use, which will fit if i don't use the cooler but is this right
Old Feb 16, 2008 | 05:15 PM
1.9 xr2 on 40's
st170 breaking
yeah just leave it off, easier all round
Old Feb 16, 2008 | 05:17 PM
J690Turbo's Avatar
J690Turbo
ok will give it ago, thanks
Old Feb 16, 2008 | 06:15 PM
bad boy rs's Avatar
bad boy rs
Default oil cooler
Ive got a zvh aswell, its not got the oil cooler either and im using a normal zetec oil filter, im thinking of running a mocal oil cooler is this going to be possible, because im going to have clearence problems aswell.
Old Feb 16, 2008 | 09:08 PM
MarkXr's Avatar
MarkXr
I have an elbow fitted to the oil "cooler" which allows the oil filter to be mounted a bit different.
The elbow comes off a XR4i but surely they will be factory mounted on several Ford models.
Here's a picture, hopefully it'll be large enough to be any help.
Old Feb 17, 2008 | 08:23 AM
J690Turbo's Avatar
J690Turbo
ar right that looks the job will have to get meself one of them then, thanks
Old Feb 17, 2008 | 09:14 AM
bad boy rs's Avatar
bad boy rs
Default oil cooler
May try that aswell, got any more pics mate looks nice
Brickhouse
14
Oct 3, 2015 07:28 PM
