fuel cap
Old Feb 16, 2008 | 12:44 PM
krisberic's Avatar
krisberic
Default fuel cap
My lock in my fuel cap has gone stiff and is a struggle to lock, tried wd40 but hasnt helped, does any one know if the lock is changeable or wether i need a new cap.
Old Feb 16, 2008 | 01:18 PM
robbieg's Avatar
robbieg
The fuel caps are renowned for doing this,the lock wears as the fumes from the petrol break down the grease in the lock.You can buy a rebuild kit from ford which will include a new barrel and new discs relevant to your key(which you will need to take)or if you don't want to tackle replacing the discs yourself take it to your local locksmith and he will rebuild it for you for about £20(just replace the discs).Quick fix anyway
Old Feb 16, 2008 | 01:35 PM
krisberic's Avatar
krisberic
Thanks ill give it a go
Old Feb 16, 2008 | 02:15 PM
Aaroncast's Avatar
Aaroncast
or get one from a breakers!-mine got harder to open when fuel prices started to rise!!!!!!!!!!!!!!!!!!!!!!!
Old Feb 16, 2008 | 04:22 PM
THE RADMAN's Avatar
THE RADMAN
youd need a diff key then?
Old Feb 16, 2008 | 06:16 PM
MATCOS's Avatar
MATCOS
Mine has done this a couple of times over the last 7 years, I just soaked it with wd40 and after a while it worked loose, it's worked twice so worth persevering
Old Feb 19, 2008 | 11:30 AM
Paul_Painter's Avatar
Paul_Painter
Mine was stiff when I bought the car.
You just need to take it apart, clean it and grease it.
There is a circlip on the back, just unclip this and it literally falls apart.
Then just clean it and grease it, try to use a thin light grease like silicone. WD40 is not really any good as it literally dissapears.
Paul
Old Feb 19, 2008 | 01:52 PM
krisberic's Avatar
krisberic
I noticed the circlip and was very tempted to dismantle it but was afraid it mite all fall into millions of bits and risk not bein able to put cap back on
Old Feb 19, 2008 | 03:52 PM
robbieg's Avatar
robbieg
The circlip just releases the barrel which is more or less a sealed assembly so don't worry no springs or parts will fall out.
Old Feb 19, 2008 | 04:33 PM
steviecossie's Avatar
steviecossie
i just went and got an ew lock from ford and it came with 2 keys
and it made from nylon now so you shouldnt get the same problem,
you will need to get the cap painted to suit your car tho
15
Oct 7, 2015 03:43 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
biggiejody
Sep 19, 2015 10:25 AM
shoppel
Ford Escort RS Cosworth
Sep 17, 2015 09:03 AM
