temp sender for 1988 S2
Old Feb 16, 2008 | 11:55 AM
StuRST's Avatar
StuRST
Default temp sender for 1988 S2
just been to the local motor factors to get a new one and they had 2 listed, only cheap so i bought both (can get a refund on the one that isnt needed)
does anyone know with one is right??
XTT44 - has a black band between the the fine threaded pole and the nut
XTT71 - has a blue band "
cant find a pic of the blue one or the lead for my cam
Old Feb 16, 2008 | 01:11 PM
Micky's Avatar
Micky
Well a sender from Ford is either pink or purple.Cant remember which???Regards,Micky
Old Feb 16, 2008 | 05:35 PM
homer j's Avatar
homer j
both the ones you have are wrong. the correct sender looks like the one pictured above but has a red coloured band instead of the black one. hth
regards
Tom
Old Feb 16, 2008 | 06:05 PM
StuRST's Avatar
StuRST
regards
Tom
is that a genuine ford colour or are the cheaper versions the same?? these are made by Commercial Ignition
Old Feb 16, 2008 | 08:19 PM
homer j's Avatar
homer j
the standard one that was in my erst was red and the last time i replaced it was with a standard ford one that had a red band on it too mate.
Old Feb 16, 2008 | 08:40 PM
Rick's Avatar
Rick
its pinky rather than purple from ford.
Old Feb 16, 2008 | 08:48 PM
picky775's Avatar
picky775
True it is kind off a pinky colour
Mark RS
Oct 12, 2015 06:01 AM
Fil
Sep 30, 2015 12:08 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Ben26
Sep 3, 2015 07:55 PM
