Thread size info needed - Mr Rainbird if you please
Quote from Mike's site:
To suit RS Turbos and Cosworths (direct fitment into OE fitting on inlet manifold), just two wires to connect (earth and ignition live) and a sensor to screw in inlet manifold. Samples every 1s, backlit, lifetime warranty (manufacturing defects). Can be upgraded to control ERL water injection kit. Cut out required is 45mm x 22mm. Bezel size is 48mm x 24mm. BLUE backlit. To wire up, solid coloured wire is ignition live, striped is earth.
Sorry Bill, me being dumb not postin upwhole story
Gettin a machined Fester EFI manifold/cossie throtle body done, and i'll need to get the sensor tapped in hence needing to know the size and thread of the sensor
Gary, i was goin to get you to do it while you had the manifold, but thought i'd ask while you were away, to make sure i got the right thread size etc....
If you already have the tap the correct size, game on
Thanks
Thanks
