COSSI T5 HYDRAULIC CLUTCH
Has anybody used the Burton hydraulic clutch cylinder ( the one that goes over the primary shaft) are they any good or is it better to do a external one?
IAN
IAN
IAN
IAN
IAN
IAN
Highly reccomended
The kit from burtons comes from Retro ford, so cheaper to buy direct.
If you use this kit with a twin plate AP clutch you will need a spacer made to space the center cylinder forward to meet the clutch.
You can use it with a normal AP paddle clutch no problems.
Ive got an external one on mine, mk1 cortina slave cylinder, whole lot cost me around £60 to do
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
