Are all 4x4 cossie c/l motors the same ?
no
pre facelifts use wires
post facelift ones use cables
assuming you mean the pre and post facelift from the 89-90 spec cars
if you are on about the 91-92 change then they are the same
but the rear doors use a 3 wire and the fronts use a 4 wire plug as the fornts are the masters and the rears are just slaves
truffleshuffle
Sep 10, 2015 09:35 PM
