compression ratio
Old Feb 12, 2008 | 05:52 PM
NATH-RSZT's Avatar
NATH-RSZT
Default compression ratio
Right this is for anyone that can answer . Now the 2.0l silvertop zetec engine has a 1.5mm thick head gasket and the pistons petrude 0.5mm from the block, The blacktop zetec engine has a metal gasket about 0.4mm or even thinner and the pistons are 0.5mm below deck and have a big dish in them, What i want to know is roughly what CR would a blcktop engine be with a thicker silver top gasket. What i'm thinking is if using a blacktop engine and a thick head gasket a decomp plate is not needed for turbo applications. Also do the BT and the ST cylinder heads have the same cc.
When it comes to cr's It goes over my head a little and abit of knowledge on this subject would help me out.
Old Oct 10, 2008 | 02:12 AM
stembo21's Avatar
stembo21
do the job right and you wount need decomp plate
Old Oct 11, 2008 | 06:53 AM
vibrating_cake's Avatar
vibrating_cake
and post it up on here so i can copy in about 6month time when the capper gets a nice turbo!
Old Oct 11, 2008 | 11:38 AM
siward's Avatar
siward
Thumbs down
I thought you were are turbo engine builder?
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
