P100 brake upgrade
Old Feb 12, 2008 | 05:19 PM
daveugc's Avatar
daveugc
Default P100 brake upgrade
Hi does anyone know what people use to upgrade p100 brakes, i still want to use the 5 stud hubs any idears
Thanks alot David
Old Feb 12, 2008 | 05:49 PM
Moondust_crust's Avatar
Moondust_crust
good question , ill also be waiting for a reply
Old Feb 13, 2008 | 08:31 AM
Your brake discs are 240mm and have a height of 58mm.
This is the same as a lot of MK1 sierra's, so any brake kit that will fit a these will fit yours too, only you will have to have the discs redrilled for 5 stud but easy to do, but if going ally bells then even easier as drilled at time.
Old Feb 13, 2008 | 02:54 PM
Alvyn's Avatar
Alvyn
what about using the Granada set up as they are 5 studs!
Old Feb 13, 2008 | 03:52 PM
charlie luciano's Avatar
charlie luciano
Or ford transit?
Luciano
Old Feb 14, 2008 | 08:54 AM
AFAIK the P100 had a unique PCD ?
Old Feb 14, 2008 | 02:42 PM
dojj's Avatar
dojj
Resident Wrestling Legend
transit stuff
Old Feb 19, 2008 | 06:46 PM
Moose 130's Avatar
Moose 130
You could change the complete upright to a granada one, better brakes 5 stud (although different?)
P100's are great to modify as almost everything is available from one Ford or another.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
