offset of rondells
Old Feb 12, 2008 | 03:32 PM
R5COS's Avatar
R5COS
Default offset of rondells
hi all came accross a set of 8 by 18" rondells for my escos which im gonna reburb and paint white as ive never seen white rondells on a red escos... got one last nite to see if they would clear the brakes which are AP 6 pots with a 356mm disk, its really really tight in there and the wheel just barely touches the calliper, what size of spacer do you think would i need to get ?? and what ET are the rondells ??
Old Feb 12, 2008 | 03:41 PM
Kelv's Avatar
Kelv
Almost there!
Rondells are et18.
i wouldnt have thought the wheels should touch the caliper, a fair few people run that brake setup with those wheels.
but if you only need to give a slight bit of an increase in clearance then just go for the slimest spacer thats available, no point adding any more than is needed
Old Feb 12, 2008 | 03:45 PM
PewteRS's Avatar
PewteRS
I thought they were 8.5x18 ??
Old Feb 12, 2008 | 03:53 PM
Kelv's Avatar
Kelv
Almost there!
Actually you will be correct Mark, i didnt even pick up on that
Old Feb 12, 2008 | 03:54 PM
PewteRS's Avatar
PewteRS
Old Feb 12, 2008 | 04:46 PM
AJC's Avatar
AJC
PewteRS
bookworm
Old Feb 12, 2008 | 04:55 PM
PewteRS's Avatar
PewteRS
Originally Posted by AJC
PewteRS
bookworm
Now where did i put that anorak
Old Feb 12, 2008 | 04:57 PM
AJC's Avatar
AJC
Old Feb 12, 2008 | 07:33 PM
MONSTER's Avatar
MONSTER
I have the same brake set up as you and 1 of my rondells just slightly touched the caliper too, the other 3 were close but didn't touch
try another wheel & see if its the same
If you need some spacers let me know, I can sort you some 1mm spacers
Old Feb 13, 2008 | 08:11 AM
R5COS's Avatar
R5COS
sorry guys my bad they are 8.5 by 18"
IainRS1700T
Sep 25, 2015 06:44 AM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
turbotrev
14
Sep 6, 2015 10:27 AM
track.focus'd
Aug 12, 2015 05:53 PM
POWARTEK
Sep 20, 2004 12:05 PM
