2wd saff crank pulley?
Old Feb 9, 2008 | 06:40 PM
s1 dean's Avatar
s1 dean
Default 2wd saff crank pulley?
my crank pulley has got a seriously damaged pickup lug for the tdc sensor (most of it is missing)
i'm having problems getting my car running could this be the fault? or would it just run on 3 cylinders with just 3 lugs?
cheers
Old Feb 9, 2008 | 06:43 PM
It depends HOW damaged, it is unlikely to make it run on three.
You coulkd just take the pulley off and get the lugs machined down to equal depth/protrusion, the reposition the sensor ?
Old Feb 9, 2008 | 08:26 PM
s1 dean's Avatar
s1 dean
theres hardly anything left of one lug tabetha i've only got spark and injector pulse at one cylinder and this is the only thing left that i can think of that may cause it
i hate cars
Old Feb 10, 2008 | 08:49 AM
If that is the case, it needs a new trigger wheel, about £5, available from TRIGGERWHEELS.COM, you will have to ACCURATELY have this put on, but it is only a simple machining job, once pulley is off.
If you cannot get a 90degree's disc, just get any and cut out uneeeded ones, so you end up with four lugs 90degrees apart.
Alternatively this would be easy for a light machine shop to make, and most likely cheaper than a new/s/h one ?
Old Feb 10, 2008 | 08:13 PM
s1 dean's Avatar
s1 dean
got it running today tabetha i've got my mates crank pulley on now and it's fine (cheers james) but thankyou for your time and help tabetha your a star
Old Feb 11, 2008 | 07:44 AM
It MUST have been seriously shagged to do that as they will pick up out if range by a hell of a long way.
Glad you got it running ok again.
Nov 1, 2015 06:53 PM
cossie330
Sep 27, 2015 04:13 PM
DavidK
Sep 27, 2015 02:55 PM
ajamesc
Sep 27, 2015 02:25 PM
Russ Payne
Sep 25, 2015 08:29 PM
