Just had the cossie out
First time out of the garage this year, gave it a bit of a clean and did a few bits and bob's!
Put these back on after a rebuild....
got them set a tad lower than before, dont know whether to rasie it or not?
Took the back seats out, was half expecting to find some nasty rust, but i just found alot of sweets/rubbish/reciepts from tesco newcastle in 1991!
and after a while idleing, the voltage finally settled to a normal place, the battery was very flat!
Got alot to do before april yet, need to change the Rad, put an RS500 cooler on, possibly a new turbo and polybush it!
comments welcome!
comments welcome!
yeah, thats one of my next things to check, i may even wire a gauge into the fuel pump so i can keep an eye on its voltage! whats acceptable on them?
Ideally you want to see battery voltage m8,i rewired mine straight from the battery with an inline fuse using the original wires in the boot to feed a relay .
Russ Payne
Sep 25, 2015 08:29 PM
