piston size- sapph cossie help!
Old Feb 8, 2008 | 01:32 AM
coachworz's Avatar
coachworz
Default piston size- sapph cossie help!
i neeed to rebuilt my engine soon . should i use std size piston or oversize? what oversize should i be using? .25? .50? or 1.0 ? also what is the advantage of using lower compression piston?
Old Feb 8, 2008 | 07:34 AM
It is not so much a choice of which to use, it will be determined for you due to bore wear, as to whihc size is needed, ie a re ring with the pistons that are in it at the moment, or if bores are worn, then a rebore with the next size up pistons/rings.
The advantage of lower compression pistons is if you want to run a LOT more power, with lower CR you can boost a lot harder.
Old Feb 8, 2008 | 02:29 PM
coachworz's Avatar
coachworz
will that in any way affect turbo lag if i lower the CR ? also how will my current mapping be affected by the change of lowered CR and slightly oversize piston? thanks alot!
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
DavidK
Sep 27, 2015 02:55 PM
