connect breather to inlet manifold or not?
Old Oct 16, 2004 | 12:27 PM
ballin's Avatar
ballin
Default connect breather to inlet manifold or not?
bit confused on this one!
got the instructions thru from Spec-R (thanks ) on fitting the oil breather to the s2, and on there it says to connect one outlet to the elbow on the inlet manifold as per the original breather.
I read on here a while back many people including Karl @ NMS say dont do this as you are pressurising the breather with boost which obviously aint good!
Whats the best thing to do in this case, connect it with a non-return valve or not connect it? Why is it connected there in the first place anyway, cant work that out!
Secondly another connection goes to the metering unit, i thought one point of an uprated oil breather is that it doesnt return it to here, as this will force it back thru the boost pipes again
anyone shed any light? ta!
Old Oct 17, 2004 | 09:53 AM
ballin's Avatar
ballin
boink for ideas?
Old Oct 17, 2004 | 09:59 AM
Matt's Avatar
Matt
production cars are all about emmissions, breathers are routed back to the engine so any emmissions are consumed
my rst didnt run the breather back to an inlet tap, i just blocked the hose off and used the tap for the boost gauge.
the metering unit again dont have to be routed to the afm, vent it to atmos under the car and block off the afm
Old Oct 17, 2004 | 10:07 AM
ballin's Avatar
ballin
ah ok mate so its just done for emmisions got ya
Old Oct 17, 2004 | 10:18 AM
Paddy's Avatar
Paddy
Legend
Rich, you want me to come round and show you how mines connected?
Old Oct 17, 2004 | 10:23 AM
ballin's Avatar
ballin
cheers paddy, i got instructions thru now of how to fit it so shud be alrite but i remember on your thread sumthin about not connectin up to the inlet manifold. does yours have a connection for it or dont bailey use that, and what about venting yours, have you done it to atmosphere or metering unit?
cheers
Old Oct 17, 2004 | 10:27 AM
Paddy's Avatar
Paddy
Legend
Aw Rich, it's easier to show mate, you know how untechnical I am.
If you mean the elbow off the top of the throttle body, I had it taped up with duck tape but now I've sorted it
Old Oct 17, 2004 | 10:32 AM
ballin's Avatar
ballin
hah ok mate ill take a lookie at yours then
wot u up 2 this arvo, dont put urself out tho i prob. wont fit it today anyway
Old Oct 17, 2004 | 10:34 AM
Paddy's Avatar
Paddy
Legend
It'll take about 20 minutes to fit. I was planning on having a nap this afternoon.
Hehe. are you up and about now? It could be done and fitted by 1pm?
Old Oct 17, 2004 | 10:37 AM
ballin's Avatar
ballin
cor blimey, go on then cheers for that mate im still half asleep from last nite so u'll have to do it (only jokin *ahem* )
u want a brew ready?
Old Oct 17, 2004 | 10:40 AM
Paddy's Avatar
Paddy
Legend
cool, I'll warm the car up and should be with you in 15 mins.
I like my coffee like I love my men. Hot, Black and strong.
With no sugar and in a cup. Which is kind of where the analogy brakes down.
Old Oct 17, 2004 | 10:42 AM
ballin's Avatar
ballin
aritey dude ill get myself ready and be waiting for you
Old Oct 17, 2004 | 10:59 PM
IANS2RST's Avatar
IANS2RST
you can connect it to the inlet manifold if you use a 1 way valve, there should have been 1 in the box I sent you
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
stevecfrst1
Sep 30, 2015 05:18 AM
caprixpack
Sep 25, 2015 07:53 PM
