Sapph 4x4 holding back
Old Feb 7, 2008 | 03:13 PM
magenta's Avatar
magenta
Default Sapph 4x4 holding back
Car judders through low-mid range revs, like a misfire. Last week the oil cap was loose resulting in a bit of oil in the engine bay but its bone dry now.
What to check? Plugs and leads are almost new.
Old Feb 8, 2008 | 04:53 AM
stevecossy's Avatar
stevecossy
Ya dont say the spec but if uprated then check plug gaps should be 0.5-0.6 mm also worth checking leads and phase sensor gap/timing
Old Feb 8, 2008 | 06:10 AM
KSA-Cossie's Avatar
KSA-Cossie
Cap and rotor arm ?
Karl 3dr
102
Oct 14, 2016 08:17 PM
mrmann
Aug 20, 2015 11:24 PM
IAN RS2k
Aug 18, 2015 07:51 PM
pegaz
11
Aug 9, 2015 06:40 PM
