escort mk6 gti nocking help ?
hi over the last week i have been getting a nocking noise
comeing from my front passenger side wheel if i turn right it gose worse if i go leth you can not here it
the nocking is thier from start upto 30 35 mph then goes
their is no play in the wheel bearing
has anyone had this problem and can anyone help me solve it ?
Well, I dont know, but if you have checked all the bushes and you say it happens in a straight line and gets worse in corners, it could be something mechanical, is it constant? or does it only happen over bumps?
Check the drive shaft,i had the same problem a while back,put new shafts in and it stopped.mine knocked at low speed then stopped.May not be that but worth checkin.
i had car at my mates garage tonight checkt car all over iv bent my drivers side drive shaft a few week ago a spun out on some oil all over road hit curb at 40 ish i bent the track rod arm replaced that and seemed normal till i took mt 17 off and put my 15s back on then i could feal the nocking more
im ordering 1 tmz should be a nice price
im not haveing mutch luck
Dr. Ickxs
Sep 15, 2015 10:15 PM
