Focus RS calipers onto a cossie
Originally Posted by Alps Pacino
Think dicko might have a set ? user name dicko&sarah
do you know what sort of money these go for?
I assume not a lot as the VW equivalent is about 15 quid, but obviously that doesnt include cossie tax
Making brackets up is ceratinly an option, its not rocket science after all, just cant be bothered spending the time to do it if there are some cheap ones readily available anyway
Ratty making some brackets for another conversion at the moment, hes made them out of wood first so he can shape and drill as needed, then takes the templates to engineering place and they charge him beer money to copy it out of Ali or steel
I hate the way the caliper sits on Cossies..... looks like it has slipped down or about to fall off...lol
Brom also made brackets to fit FRS discs and calipers onto RST's as well (my mate had them on his made by Brom)
Steve
Steve
Do Evo 6 Brembo's fit on Cossies?
Im presuming that its just a case of brackets too?
Are they the same?
I got some lyin around thats all, fronts and rears altough rears prob wont go on because of the fart on they will be to fit.
Are they the same?
Originally Posted by DogSmoke
Gracie you cunt!!
I know that was uncalled for but I am half cut and it felt like the right thing to do
Originally Posted by Jasesapphy
i reckon about a 325-330
It only looks as big as the bell
Ours is almost as big as the complete rotor
Originally Posted by NUTS RuS
What sized rotor is under thet caliper Paul ?
I had to modify the caliper slightly by removing a couple of metal lugs so the width of the disc wouldn't be a problem, nothing 5 mins with a file and angle grinder didn't sort
Tony - Maybe the red calipers arn't focus RS ones, but a bigger flavour?
Interestingly, I have a pair of Brembo's from a Rangerover Sport for sale that will make Focus RS calipers look like toys in the size department
I had my brackets made several years ago. Mocked them up myself and had a machiner make them. Cost me more as I only wanted one set (maybe around £80) and I had to do it again as I made a minor fuck-up with measurements. But this was at a time when very few other people had done it (around 4 years ago, maybe more?).
track.focus'd
Aug 12, 2015 05:53 PM
