fiesta t3 prts
Escort RS Turbo T3 turbo
Escort RS Turbo exhaust elbow (90 degree bend mounted directly to the turbo)
Escort RS Turbo exhaust manifold
Escort RS Turbo downpipe (or aftermarket replacement, stainless etc)
Escort RS Turbo oil feed pipe (braided hose with threaded fittings)
Escort RS Turbo oil return drain pipe (metal pipe with flanged fitting)
Escort RS Turbo oil return elbow pipe
Escort RS Turbo water feed pipe n/a
-31 or equivalent actuator
two (11mm usually) nuts to fit the actuator thread
4 extra 50-70mm hose clips
Escort rs turbo Manifold Bolts
Escort rs turbo Manifold Washers
Escort RS Turbo exhaust manifold I HAVE ONE
Escort RS Turbo oil feed pipe (braided hose with threaded fittings) I HAVE ONE
Escort RS Turbo oil return drain pipe (metal pipe with flanged fitting) I HAVE ONE
Escort RS Turbo oil return elbow pipe I HAVE ONE
Escort RS Turbo water feed pipe n/a IHAVE ONE
two (11mm usually) nuts to fit the actuator thread IHAVE THEM
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
