Horsepower guesstimate please????
Esc Cos
200 block
big wing sump
wrc gasket
standard head bolts
7.2:1 cosworth racing pistons
farndon rods
ported/polished head
BD14 inlet and exhaust cams
siemens 83lb injectors
GT30 internal wastegate
swedish plenum
500 cooler
er think thats it..
only running 1.5 bar at the mo till I get some proper boost control.
So estimate for 1.5 bar?
and one for 2 bar?
Cheers, Kev.
200 block
big wing sump
wrc gasket
standard head bolts
farndon rods
swedish plenum
500 cooler
er think thats it..
and one for 2 bar?
Cheers, Kev.
just done one with 8.1 comp ratio je pistons balanced crank and rods f1 conrod bolts big port head bd16 bd14 gt 30 55lb siemens ecc4 inlet and that made 449 at 1.6 bar and 502 at 2bar with 442lb/ft all on engine dyno so rekon youl be pretty close to that. danny@abcmotorsport
saff is working!!!...atm
Originally Posted by Alps Pacino
Thats basically the same spec as mine but i'm using a t4, stu seemed to think i had a genuine 500bhp motor when i asked him about getting it mapped
Stu @ M Developments
Oct 12, 2007 02:36 AM
The Sludge
17
Feb 7, 2006 04:47 PM
