Escos f/bumper end fixings
Does anyone know where i can get the plastic parts for the front bumper that rivet on the ends on the inside as the fixings have broke on mine or even if you can get them from fords.
Ok checked the bumper and passenger mount is perfect, driver side looks to be ok except top rivet had been replaced with a nut and bolt.
Would be looking for Ł75 plus post for the bumper ( no mounting bar or towing eye).
Microcat Finis 6 123 961 85p + VAT
They are listed for the Escos, but only give the inside bumper support, not the twist fixings so.
You have to look at a MK 1 Sierra Front Bumper Diagram on microcat.
Hope this helps..
Hope this helps..
I need the mounting bars that are used to attach the bumper to the chasis if anyone has any? - want to see what my WR front looks like, but don't want to take the mounting bars off of my original bumper
Originally Posted by mikedaf2
AlexD
i think you are thinking of the wrong parts the parts i need are the ones that are riveted to the bumper not the parts that twist fit to the car.
Typical i went to ford yesterday too..
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
