g'box removal/refitting 4x4 saph
Old Feb 5, 2008 | 08:26 PM
cossie_pol's Avatar
cossie_pol
Default g'box removal/refitting 4x4 saph
ok chaps how hard is this to do?
have heard that the 2 bolts behind the engine at the top of the box are a pain in the rs but are there any time saving tips that i should know about before starting this or any special tools i'll need?
will probably be using a ramp if i can work my may in to using a friends boss's workshop for the day!
Old Feb 5, 2008 | 09:47 PM
charlie luciano's Avatar
charlie luciano
Shouldn't be too difficult if the car is on a ramp
Luciano
Old Feb 6, 2008 | 07:02 AM
Just watch the engine doesnt tilt forward and damage the radiator. Someone told me that soneone had done this before.
Old Feb 7, 2008 | 01:35 PM
cossie_pol's Avatar
cossie_pol
Anyone know the part number for the 4x4 g'box oil??
local dealership can't find it on their system!
Tis ok found it! 5021033
is atf ok for transfer box an ep90 the diff?
Old Feb 9, 2008 | 08:48 AM
dojj's Avatar
dojj
Resident Wrestling Legend
the oil for the box is specific to the MT75 box and even ford now state they use a different one, but it's easily noticable when the gears start to crunch
but you ned to remove the gear stick first
then the exhaust and props and starter and arb before you can remove the mount but remember to undo the bellhousing bolts before removing the mount so that everything comes off nice and easy
and if you replace the bolts tht hold the engine crossmember in place with long bits of threaded rod you can move the engine up and down a bit more to give you more clearance, just remembr to undo the steering intermidiate shaft first
Old Feb 9, 2008 | 09:49 AM
jemis's Avatar
jemis
Do you have to buy the gearbox oil from ford? or are there other ways of getting it.
Old Feb 9, 2008 | 05:18 PM
cossie_pol's Avatar
cossie_pol
do you have to remove the arb?
was a right b1atch to get back in when i polybushed the front end.
dojj do you know which oil is better, the one that the above part number refers to or the newer one that ford now recommend?
And I've now heard 75/90 fully synthetic is good to use!
and also how much do you need?
can't seem to find my manual cd anywhere atm!
Old Feb 9, 2008 | 05:38 PM
dojj's Avatar
dojj
just undo it from the chassis to let th ebox drop down enough
as for the il, i can't remember off hand which one it is but ford have changed their numbers for the specific one so you'd need to find someone who knows what it is
Old Feb 9, 2008 | 06:22 PM
timster's Avatar
timster
bought oils for my 4x4 a few weeks ago,can't remember the oil for the gearbox sorry as i took it back as the 'box was full.i did use atf for the transfer box though
Old Feb 20, 2008 | 08:30 PM
saph4be's Avatar
saph4be
you can leave arb in place in place
Old Feb 20, 2008 | 11:12 PM
indycos's Avatar
indycos
helooooo!!!
i was told to use fully synthetic Castrol TAF-X 75W90
(not sure if its still called by the same name as i think some castrol oils have had recent name changes!!!)
think the same oil is used for the gearbox and diffs? but CHECK and confirm with other people before using to make sure!!!
when you remove or replace the gbox, be sure to check pipes for the heater/rad etc as these pipes tend to crack (when the engine moves they get squished and creased) causing coolant to leak from them etc
good luck, all should go well and you'll end up with a nicely serviced gearbox
Old Feb 23, 2008 | 09:51 PM
Im also wanting to know what oil to put in my 4x4 cossie gearbox. I work in a garage and we use 75/90 fully sythetic. If its ok to use this i will but if not i will use the proper oil what ever that is. So do people use automatic transmission fluid for the diffs.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Rizlablue
Sep 6, 2015 09:58 AM
Adam Graham
Sep 6, 2015 06:04 AM
