Rattle noise on Mondeo TDCI 130bhp egine/flywheel/tensioners
Old Feb 4, 2008 | 09:09 PM
forestgump100's Avatar
forestgump100
Default Rattle noise on Mondeo TDCI 130bhp egine/flywheel/tensioners
i recently bought a 2005 TDCI Zetec s mondeo 130BHP, however intermittently on idling.. it has developed a rattle noise.. very plasticy vibrating type noise like something is loose... anyone come across anything like this... when u rev the car slightlythe rattle dissapears.. and then when it falls to idle again the rattling noise comes back
any advice would be great.. thanks a lo
Old Feb 4, 2008 | 09:19 PM
Nobby_Turbocabby's Avatar
Nobby_Turbocabby
standard on all new diesels imo usually engine cover etc have a good nose lol n make sure the covers tight
Old Feb 5, 2008 | 04:19 PM
forestgump100
this engine has no cover on it... should a 2004 tdci engine have a cover over it...???
the guys in ford said it could well be the flywheel... i find that hard to believe
the car is 04 with 48k on it (hardly excessive)
the rattle sounds plasticy and vibrating rather than metallic
there are no probs with clutch,shuddering vibrating etc
the starter motor seems 100%
was advised by someoneelse that it could be tensioners on the fan belt or something... anyone comeacross this??
cheers
Old Feb 5, 2008 | 04:55 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
My peugoet HDI had to have a new bottom pulley as they are a cushion drive thingy majig and that made a plasticy clacking sound on idle. Obnly about 50 quid though.
have a look at the bottom pulley area for metal filings. You need to change it if it is that as if it shear youll have no alternatoer and probably no water pumping round
Old Feb 5, 2008 | 09:33 PM
coss1e2000's Avatar
coss1e2000
You need to change the bottom pulley, alternator belt, and alt. belt tensioner.
(Ford have brought out an upgraded pulley to stop the vibration)
They're quite easy to do
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
gingeRS
17
Oct 2, 2015 09:42 AM
The Enigma
Sep 29, 2015 10:31 AM
