Do you need a chip to run a t3
Old Feb 2, 2008 | 10:45 PM
jamie_dahl's Avatar
jamie_dahl
Default Do you need a chip to run a t3
Im running a fiesta turbo 1.6 cvh with an escort t3 upgrade on ofab . it had ofac with a 165 chip but the ecu burnt out so i did the sensable thing and upgraded.
my mate told me that to run a t3 you need a t3 chip but others have assured me that any chip will do .
whats the difference !
aparently a t3 chip tells the ecu to fuel a bit later because the t3 spins up later than the t2 and a 195 chip wont do this ,all it will do is take the limiter off the fuel. Not tell it when to fuel.
i dont know who to listen to i just need some one who is running a frst with a t3 to tell me what they've done.
any advice is appreciated.
Old Feb 2, 2008 | 11:01 PM
BRAMMER's Avatar
BRAMMER
Default Re: Do you need a chip to run a t3
If you do one thing only, and thats never ask that lad for advice again
When you said upgraded it isn't really an upgrade as such with OFAB it was just a hurdle in the Map but i'm sure MSD have overcome this now.
When you get your car chipped by a reputable company like MotorSport Development they map the car to what other goodies it has for example front mount cooler and stg 2 T3 and a high lift cam.
Take your car to a good tuners and let them sort it for you as playing with stuff you don't fully understand nearly always results in failure.
Old Feb 2, 2008 | 11:05 PM
jamie_dahl's Avatar
jamie_dahl
does that mean i dont need a chip at all i just need to get it mapped or does that mean they put a custom chip on it
Old Feb 3, 2008 | 09:23 AM
Chris69's Avatar
Chris69
you don't need a chip to run a t3, the ofab will run it fine but you will need to get the the fueling setup at the very least
Old Feb 3, 2008 | 10:37 PM
rst in breaking's Avatar
rst in breaking
as i said to you jamie, u need correct chip for your set up, a second hand chip is no good unless you are certain its for your spec.
Old Feb 4, 2008 | 10:51 PM
BRAMMER's Avatar
BRAMMER
By the sounds of it you just need a remap which would be be cheaper than a new chip, ring around a few of the good tuners and see what they charge.
Old Feb 5, 2008 | 11:19 AM
XRT_si's Avatar
XRT_si
My old fiesta ran OFAB on a T3. I had a custom chip done by MSD to match the spec. I then had the fuelling checked by another company to insure the pressure etc... was spot on. It ran like a dream.
Do it properly and get a decent chip, then get it set up.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
RSmark84
Sep 13, 2015 01:29 PM
Eigdoog
Sep 13, 2015 05:46 AM
