Group A fitted :)
One Roose hose still needs to be trimmed a bit before it sits nicely in its place. Although, it does look pretty cool where it sits now, and it misses the bonnet too
Also needs to be mapped again as its sucking more air in, where the last map was done with the dinky Viper fitted
the filter looks all nice and good mate but its sitting in the engine bay sucking in nothing but hot air. You need to enclose it somehow and try to route cold air feeds directed towards it as best u can. sucking in HOT air is bad. Ok your sucking in a larger volume of air than the standard set up but if your only sucking in the hot stuff then ur not gettin the benifits you could be.
Its obvious that part of the engine does not get hot, look how far away it is. Plus, if you look closely, when trimmed down, it will sit directly behind one of my quad lamps. So its a simple case of removing one of the units and walla...direct air feed
Originally Posted by Rab
Originally Posted by lowman
i am chilled..like a frozen mongoose.hehe
And I work for the MOD
well..the comment about group a wasnt meant directly at this thread starter..it was just a burst out of all the group A talk..or like different parts beeing group A and its all good kinda..but ..yea.
doesnt matter really
cheers people
Originally Posted by COCHYN
Originally Posted by PewteRS
Nice filter Alan anyway
bigluke200
14
Sep 2, 2015 10:35 PM
FlashRS
13
Aug 31, 2015 06:02 PM
