anyone know what this is?
Old Feb 1, 2008 | 10:29 AM
Kelv's Avatar
Kelv
Almost there!
Default anyone know what this is?
Havent a clue what this is
it was plugged in behind the dash and hooked to a dash section below the steering column.
just cutting out alot of the loom, ie plugs and wiring to Banana pod section, full alarm, wiring to centre clocks and switches that arnt needed, just dont want to cut this out before i know what it is.
any help please?
Old Feb 1, 2008 | 10:49 AM
mikedaf2's Avatar
mikedaf2
looks like the back casing of the clock
Old Feb 1, 2008 | 10:55 AM
Kelv's Avatar
Kelv
Almost there!
its not the clock mate. but very similar with the plug in wiring thats needed.
as said it clips to the dash on the lower dash section drivers side, if you remove the lower section over the fuse box and below the steering column you will see it clipped backwards to the main dash assembly.
Old Feb 1, 2008 | 11:04 AM
Rolls's Avatar
Rolls
Illumination jobbie for the dash mate- makes the clocks / bana pod glow! - I think....
Old Feb 1, 2008 | 11:31 AM
Cossie-Lee's Avatar
Cossie-Lee
Looks like a pollen filter, iv got the very same thing hanging behind the dash illuminator switch.
Old Feb 1, 2008 | 12:43 PM
Kelv's Avatar
Kelv
Almost there!
Pollen filter, how the .... ??
its a sealed block mate with a wiring terminal inset at one end, and im pretty sure no escort cossies came with pollen filters.
Rolls, sounds feasable mate, cut that bit of the loom out aswell then, lol.
Old Feb 1, 2008 | 01:14 PM
cosmo V6's Avatar
cosmo V6
lamp fail indicator relay finis code 6192590
Old Feb 1, 2008 | 01:18 PM
Kelv's Avatar
Kelv
Almost there!
Star mate
Bullett's Avatar
Bullett
that part number on the unit is too old.superseeded but not on there to match up
Old Feb 1, 2008 | 01:19 PM
Kelv's Avatar
Kelv
Almost there!
oh ok, well lucky i dont need one then i guess, lol.
looks like i need to keep it for now.
Old Feb 1, 2008 | 01:24 PM
THE RADMAN's Avatar
THE RADMAN
esc cos dont have them or do you mean a normal indicator relay? never seen one like that though
Old Feb 1, 2008 | 01:26 PM
Kelv's Avatar
Kelv
Almost there!
esc cos dont have them never seen one of them anywhere on an esc cos before,very strange
Hmmmm, the plot thickens
Old Feb 1, 2008 | 01:27 PM
THE RADMAN's Avatar
THE RADMAN
where exactly is it kelv?
Old Feb 1, 2008 | 01:29 PM
cosmo V6's Avatar
cosmo V6
should say listed with ford as lamp fail indicator relay finis code 6192590, sorry
Old Feb 1, 2008 | 01:38 PM
THE RADMAN's Avatar
THE RADMAN
should say listed as lamp fail indicator relay finis code 6192590 sorry
thats what you said?? i dont understand as sapphs had the lamp unit failure thingies but not escorts?
Old Feb 1, 2008 | 01:39 PM
Bullett's Avatar
Bullett
up behind the dash,left handside i think
Old Feb 1, 2008 | 01:42 PM
Kelv's Avatar
Kelv
Almost there!
ill get apic of exactly where it came from, both from the front and reverse of the dash.
Old Feb 1, 2008 | 01:45 PM
- Sim -'s Avatar
- Sim -
isn t this the part that makes beep if you leave the car with light on?
everything works without this connected, found this thing when I unbuild my dash - it was not connected
Old Feb 1, 2008 | 02:51 PM
The Youth.'s Avatar
The Youth.
correct, it is deffo the lights on alarm.
steve
Old Feb 1, 2008 | 03:07 PM
Kelv's Avatar
Kelv
Almost there!
so not needed, or does it sit inline of the light circuits?
Old Feb 1, 2008 | 03:09 PM
Cossie-Lee's Avatar
Cossie-Lee
was just a guess mate, and a very large one at that i had a look at mine and it looks like a useless bit of junk so i thought it could have been a pollen filter Come to think of it, i might have been looking at something else Mmm maybe i should stay off that booze..
Old Feb 1, 2008 | 04:20 PM
Rippers's Avatar
Rippers
Monte Geek
The connector looks a little bit like the Wipac unit under the dash on the left had side but I thought your Esc was a early version so maybe its a standard alarm?
Old Feb 1, 2008 | 05:20 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
My guess is the alarm, size and connector.
Old Feb 1, 2008 | 05:40 PM
THE RADMAN's Avatar
THE RADMAN
my money is on the lights on beeper
Old Feb 1, 2008 | 06:25 PM
Kelv's Avatar
Kelv
Almost there!
the plug on the back of it is exactly the same as the one for the clock
Old Feb 1, 2008 | 06:32 PM
MONSTER's Avatar
MONSTER
me too
Old Feb 1, 2008 | 10:45 PM
The Youth.'s Avatar
The Youth.
It is the light s on beeper deffo
DO I NEED TO SHOUT IT!!!!!!!
lol
steve
Old Feb 2, 2008 | 08:31 AM
MONSTER's Avatar
MONSTER
You should have said Steve
Old Feb 2, 2008 | 03:16 PM
THE RADMAN's Avatar
THE RADMAN
good one
