Zetec manifolds
Old Jan 30, 2008 | 07:04 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
Default Zetec manifolds
The cast manifolds, the metal ones that say EFI on them, is the one from the 1.8 any different to the one on the 1.6? also what is the difference between the 130 spec and the normal 1.8 one? any help would be greatly appreciated.
Old Jan 30, 2008 | 09:07 PM
Wardy257's Avatar
Wardy257
The RS1800 inlet has slightly bigger ports and is the one to use if you are keeping the original EFI.
Old Jan 31, 2008 | 07:50 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
is the standard 1.8 manifold an upgrade over the 1.6 one?
130 spec ones are a littlehard to come by and expensive at the minute, money is tight.
Old Feb 2, 2008 | 10:32 AM
Wardy257's Avatar
Wardy257
I think they are the same. Some normal escorts had the 130 bhp spec engine so it's worth chekcign engine numbers etc to see if you can fin one.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
caprixpack
Sep 25, 2015 07:53 PM
