4 speed to 5 speed mk4 swap.
Old Jan 29, 2008 | 02:34 PM
cosworth_wannabee's Avatar
cosworth_wannabee
Default 4 speed to 5 speed mk4 swap.
hello every1
my mk4 escort started as a 1.3 bonus, and now currently has a xr cvh with standard 4 speed in it. i want to put either an xr or rs 5 speed in to it.
if i get the box and selector, will the 5 speed fit evrything else...i.e. gearbox cradle and drive shafts??
if so, can a s2 rs limited slip diff box be used as a direct swap with the bonus shafts and gearbox cradle?? thanx all!
Old Jan 29, 2008 | 06:55 PM
Nobby_Turbocabby's Avatar
Nobby_Turbocabby
the 5 speed will bolt straight up nothing else needed! where u in brum mate?
Old Jan 29, 2008 | 07:23 PM
cosworth_wannabee
great barr, just off junction 7 m6 m8 cheers so just a 5 speed box and selector needed then. that makes it alot easier for me to do
Old Jan 29, 2008 | 07:24 PM
cosworth_wannabee
anyone know how to measure / fill the level of gear box oil???
Old Jan 29, 2008 | 07:34 PM
Nobby_Turbocabby
shud be on the frton of the box mate
Old Jan 30, 2008 | 12:48 PM
xrmalin's Avatar
xrmalin
Empty all the old oil out and measure how much you put back in.I think it tells you in the back of the haynes manual ive not got mine at home otherwise i'd tell you im sure some one on here will be able to let you know.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
streetracer
Sep 24, 2015 08:14 PM
bassboy
Sep 10, 2015 08:54 PM
