RS 4wd Cosworth Bottom End Rebuild Parts
Old Jan 28, 2008 | 12:18 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
Default RS 4wd Cosworth Bottom End Rebuild Parts
0.5mm O/S Mahle Piston 8;2;1
Genuine Small End Bushes
ARP Pro Series Rod Bolts
ARP Flywheel Bolts
4wd Genuine Cosworth Oil Pump & Hex Drive
Genuine Rear & Front Seals
Genuine Sump Seals
£680 Delivered, can also supply other gaskets and bearings if needed
Regards Matt
IAN RS2k
Aug 18, 2015 07:51 PM
john_3.0s
Aug 15, 2015 07:44 AM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
