zetec help
oh right kewl
erm will the cvh gearbox take the power though? i had a 1.1 gearbox on my 1.6cvh and i blew the difff up
mind u a 1.6cvht is probly a bit more durable. Oh whats the loom like to do for the conversion? My base car is a 1.6 carb cvh
BY THE WAY m4dyeti your car is EXACTLY how i want mine beast of a car mate
mind u a 1.6cvht is probly a bit more durable. Oh whats the loom like to do for the conversion? My base car is a 1.6 carb cvh BY THE WAY m4dyeti your car is EXACTLY how i want mine beast of a car mate
You need to convert to efi set up so fuel tank and lines will be needed.
Gearbox well depends on power really..
180 bhp standard cvh box with diff
240 bhp stage 2 box with quaife diff
350 bhp stage2 + box with quaife diff.
400+ st170 or mtx box with quaife diff equal length shafts.
wiring loom not sure as im not doing mine... but im sure if you ask on here or fiestaturbo.com more so someone will help out..
Cheers for the comments of mine mate
alright cheers mate always knew ud be help in my lil project sooner or later
my plans at the minute though is just to get the whole lump in with the actual mondeo loom and go from there.
petrol tank issue will probly be overcome by stickin the mondeo tank in the back or pissbnly boot? What dya think would be wise?
Bearing in mind im kinda tight for cash for a lil bit lol
oh how much did u pay for your rollcage??
my plans at the minute though is just to get the whole lump in with the actual mondeo loom and go from there.petrol tank issue will probly be overcome by stickin the mondeo tank in the back or pissbnly boot? What dya think would be wise?
Fuel system buy a mk3 fiesta tank and lines mate it wil bolt to the floor pan perfectly that way cost you prob Ł60 tops for that....
yes the tank has the pump situated in the top of the tank and the pipes run out fo the top and then under the car up to the bulkhead where they join the filter, then feed in the injector rail and back out the pressure regulator under the car into the tank again.
standard engine with a set of low comp pistons 270 is pretty easy..
have a look on fiestaturbo.com on the zetec guide and it tells you whats needed.... your be surpprised.
anything over 350-400 your looking at alot of money
ok i like ur style lol
for now though im going to put the 2 litr in as it is and use it like that see what its like then in maybe 6 months take it off the road again and do a turbo re build
make good use of it get suspension brakes all sorted and keep tracking it..
then over the winter sling the turbo in and all set for new year.
otherwise its "yeah il do it in 2 months" and it will take you twice as long
but what about the hub and disk size?? are the 4x4 ones like 284 mm? So will the cossie calipers mount to my hub then or any adjustments??
best to look on ft.com there will be a guide on there for it for sure.
It has custom spec pistons which are larger so equates to just under 2.1.
the head has had loads of work and is Sunny's old head (178.9mph).
I have gone for a differnt turbo spec and transmission choice, along with a lighter shell so should see this top speed figure and beyone hopefully.
Although the car is built to be a track car not a 1/4mile topspeed runner
oh right i know that sunny and his fiesta that was quick lol yeah id prefer it to be a track car keep some handling so you can go quicker round corners
me and my mate stevegti2 reakon 195/50(45??)/15 are the best size of wheel what size would u say was best for handlin?
Spot on there mate ive had 17s 16s and now 15s with 195 50 15 tyres r888s super soft compound and you will have a real weapon
if your turboing it then jut use a standard frs down pipe or a shortend escort rs turbo and join that to your system.
Im having a custom one built due to the bhp im having which is 3" diameter
fuckin hell like scaffold thats how i like it lol. so what exhaust will i use then? i havent even looked at the zetec exhaust system
i just want one wacked on until i buy a nice ss one
ok mate going to have to do that for now
where do u think will be the best place?? im thinkin just after the downpipe cos of the cat?? take the cat away and adapt the fiesta exhaust from there
mk3ste
Oct 17, 2021 10:09 AM
SMILER258
Sep 28, 2015 09:04 AM
