Fiesta RST - What to look for...
I'm thinking about looking for a Fiesta RS Turbo, and was just wondering if anyone could give me some ideas on what to look out for, common problem areas etc etc
As with all CVH cars, check the oil's been changed regularly.
Rust is a big problem around the fuel filler cap, stick your hand under the rear arches to check for rust, under the boot carpet and in the sunroof well (many go here and no many people check!)
Run your hands under the bodykit on the rear arches to check for rot on the sills. Check the gearchange isn't sloppy and cruise at 35 in 5th and put your foot down to check for turbo wear.
The car is easy enough mechanically to sort out, it's just a CVH, but the check the radiator they're getting difficult to source.
The trim in nearly impossible to get a hold of good seats, so check for the normal wear on the bolsters etc.
Rust is the main thing with the Mk3 Fiesta to check, been utterly thorough when checking. Apart from that they're great little cars.
Cheers for the info matey
The car i've seen is a 1990 H plate in red, and IN THE PICS, looks quite good in the places you've mentioned eg filler cap etc! There is some rust on the scuttle panel and tailgate tho
On the engine side of things tho, it says the oil has been changed every 1000 Miles with regular servicing, using original Ford parts etc!!
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
