converting 4x4 to 2wd
Originally Posted by charlie luciano
Why? just go and buy a 2wd
Luciano
Luciano
proper ford gloss black
filthy engine
Hi
My mate has just converted his & it was alot harder to do than what you would think & after all the hassle it still dont drive aswell as a proper 2wd.
When you change the sump you also have to change the oil pick up.
There isnt a bracket where there should be to bolt the 2wd gearbox to.
He also had to buy new suspension because when he removed the front diff & shafts etc the car sat with its nose in the air because of weight difference.
Cheers Matt
Cheers Matt
Originally Posted by mattrst90spec
Hi
Cheers Matt
Cheers Matt
1) bolt a length of 50mm box section to the mount in the floor on the 4x4 floorpan and mount the 2WD gearbox crossmember to that
2) there is another ford crossmember available that bolts to the 4x4 floor and takes the 2WD T5 gearbox
i reshelled 2WD engine and transmission into a 4x4 shell, but i had everything from the 2WD shell to use.
don't forget that the 4x4 abs will not work correctly in 2WD - the calibration in the ecu is different. that is why they have different colour connectors that do not line up and the looms are different
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
