turbo on pinto?
Hey every body.
i am Rob from the Netherlands and i have a question
does a turbo + manifold of a Td sierra Fit a 2.0 Pinto?
on how much psi does that turbo normaly run? and how to adjust that?
is there anything that i have to modify to fit an turbo to my pinto?
Thnx
Rob
Thnx
Rob
No. And don't use a Diesel turbo on a petrol engine, it will burn out.
Look on www.turbosport.co.uk for pinto turbo stuuf
i had a mk 2 escort rs2000 and that had an original turbo tecnics turbo charges pinto
the used to carry out these conversions years ago and it ran a nice 6 psi and to be honest was quite sharp and quick little set up
look in the old skool section bet someone in there is running exactly want you want
Adam Graham
Sep 6, 2015 06:04 AM
