AP brake questions for 18" comp mo's
Old Jan 24, 2008 | 05:38 PM
McGoo 69's Avatar
McGoo 69
Default AP brake questions for 18" comp mo's
Right i recently bought a 6pot AP caliper of ebay as it was dirt cheap and brand new
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=250200809742
whats the max size disc i can use under a 18" comp mo rim?
and wheres the best place to get the matching caliper?
the part number is CP3796-26s4
also what size rear brake should i go for?
Old Jan 24, 2008 | 06:00 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Re: AP brake questions for 18" comp mo's
The other caliper will cost you Ł773.96 plus vat!!! They are designed for a 356x28mm disc, it will probably accept bigger but you will find it hard to get a bigger disc in such a narrow width, most discs 355 or bigger are 32mm wide or more. I doubt you will find another single caliper to match it up with without buying new, I'm sure Tim would have done so if that was the case. Sell it on and buy a new kit, I'm happy to oblige.
Old Jan 24, 2008 | 06:02 PM
Ryan's Avatar
Ryan
opps
Old Jan 24, 2008 | 06:05 PM
twoblacklines's Avatar
twoblacklines
LOL
Old Jan 24, 2008 | 06:17 PM
McGoo 69's Avatar
McGoo 69
i knew the price of a caliper new its still going to be cheaper than a complete kit
unless you can do the same kit for around Ł1000
ive found some discs and bells i think so there going ot be bought
will need your help to make some bigger rear discs for standerd cosworth calipers though
oh and the engine fitting haha (but that will be towards the end of febuary when the car is back on its wheels)
Old Jan 24, 2008 | 06:22 PM
Martin-Hadland
Make sure the discs are a pair and that the bells are the correct offset, you then still have to get brackets made. I reckon you have no chance of getting a kit on your car using that caliper for 1k unless you use a standard caliper on the other side..
Old Jan 24, 2008 | 06:26 PM
McGoo 69's Avatar
McGoo 69
there not urgant so i can keep my eyes open.
what can you do for me regards rear discs
i need to get my car rolling first with a functional handbrake so i can talk to you properly about having the st engine fitted
its no good atm with no wheels
yatta
May 21, 2016 10:31 PM
155lee
Oct 27, 2015 04:55 AM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
