zetec flat spots
Old Jan 23, 2008 | 08:12 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
Default zetec flat spots
Im curious what could cause this, at about 3k i get a flat spot til about 3700 rpm, wondering what fixes/suggestions there could be for this. Its a 2.0 silvertop by the way.
Old Jan 24, 2008 | 05:33 AM
Try cleaning the MAF.
Old Jan 24, 2008 | 08:33 AM
LHD220Turbo's Avatar
LHD220Turbo
has it always done it? or just started suddenly.
if you havent had the car mapped i suggest getting it done; a decent mapper can iron out flat spots.
Old Jan 24, 2008 | 07:50 PM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
Its done it since I got it. Thanks for the suggestion but I cant see how mapping would make any difference, its all standard apart from a k&n filter.
Old Jan 24, 2008 | 08:13 PM
LHD220Turbo
trust me a map would get rid of it; a friend had a 328i bmw with a flat spot; got it mapped and it was gone and plus it will give you a smother motor and be better on fuel
map are always worthwhile for standard and modified cars imo
Old Jan 27, 2008 | 09:42 PM
Wardy257's Avatar
Wardy257
Are using the standard ECU and EFI set up?
Old Jan 28, 2008 | 05:47 AM
zetecapri's Avatar
zetecapri
2.0 16v Turbo
Yeah, however they are 1.6 inlet and exhaust, with 2.0 injectors.
Old Jan 28, 2008 | 06:11 PM
Wardy257's Avatar
Wardy257
Well get a RS1800 inlet and a megasquirt. You should see around 150 bhp as that is all the inlet will flow NA.
You will never get it running properly mixing and matching parts like you have.
Old Feb 3, 2008 | 11:19 PM
Reid's Avatar
Reid
i did and mine was, as tabetha said it sounds like a maf problem. im not 100% that you can clean them as such. but change it to a known working one. are you using the 2l MAF and TB?
Old Feb 4, 2008 | 03:44 PM
Wardy257's Avatar
Wardy257
You can clean the MAF with brake or carb cleaner.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
stevecfrst1
Sep 30, 2015 05:18 AM
mondeomark
Sep 28, 2015 06:28 AM
