does any one know what the extra wire is for on an ofab loom
Old Jan 23, 2008 | 05:52 PM
jamie_dahl's Avatar
jamie_dahl
Default does any one know what the extra wire is for on an ofab loom
ive decided to upgrade my ofac loom to an ofab but ive got one bloody wire left over .cant for the life of me work out where it goes.the car starts but doesnt even idle it just dies straight away .if anyone can give me some advice it would be much apreciated.
Old Jan 23, 2008 | 05:54 PM
kjc300's Avatar
kjc300
what colour is it and what pin does it go to on the ecu plug? I think I have a haynes manual out in the shed for when I put a frst engine in my old mk5 esc.
Old Jan 23, 2008 | 06:51 PM
rst in breaking's Avatar
rst in breaking
he has the fuel rail plug, cps, iscv, engine loom to car loom, oil pressure switch, coil pack and evrything on the panel with the map sensor but has one plug left , get the colours up mate
Old Jan 23, 2008 | 06:53 PM
rst in breaking
he said the wire to the plug are black and brown with a yellow trace?
Old Jan 23, 2008 | 08:17 PM
kjc300's Avatar
kjc300
The only one I can see is a 2 pin plug - one black wire, one brown n yellow is the idle speed control valve!!
Old Jan 23, 2008 | 08:18 PM
rst in breaking
i think but cant remember off my head but think it is a 2 pin plug and doesnt have a long stretch of loom on it
Old Jan 23, 2008 | 08:38 PM
kjc300's Avatar
kjc300
right this is what i have on the wiring diagram:-
air temp sensor - 2 pin, Bn/Y and Bn
engine temp sensor - 2 pin, Bn and Bn/Gn
CO pot - 3 pin, Bn/Bk and Bn and Bn
idle speed cont valve - 2 pin, Bk and Bn/Y
Speed sensor (crank?) - 3 pin, Bn/W and Bn and Bk
injectors - 2 pin, Bk and Bn x 4 plugs
Map sensor - 3 pin, Bn/y and Bn and Bn/Bk
TPS - 3 pin, Bn/Gn and Bn/Bk and Bn
Boost control - 2 pin, Bn/Gn and Bk
Old Jan 23, 2008 | 08:46 PM
rst in breaking
just thought after seeing that, its prob for the amal valve?
Old Jan 23, 2008 | 08:56 PM
kjc300's Avatar
kjc300
It would run fine without that plugged in though!! unless he got em mixed up I suppose???
Old Jan 23, 2008 | 08:58 PM
rst in breaking
i know it would run fine without it as would it without the iscv but couldnt work out what it was, does ofac have amal valve plug?
Old Jan 23, 2008 | 09:28 PM
kjc300's Avatar
kjc300
yes, I swapped the mk5 loom for a fiesta rst one (ofac), Then once I realised the mk5 one was exactly the same except for the amal valve wiring so swapped back so I could put the ecu in the proper place.
Has he got an ofab ecu too?? sorry if thats a mong question, but the only difference I know is the map sensors are different, ofab has a weber type one.
Old Jan 23, 2008 | 10:11 PM
jamie_dahl's Avatar
jamie_dahl
cheers kev real help ill see if i can get it sorted in the morning
Old Jan 24, 2008 | 12:14 AM
jamie_dahl's Avatar
jamie_dahl
thanks everyone hopefully this info will come in handy
Old Jan 24, 2008 | 08:36 PM
jamie_dahl's Avatar
jamie_dahl
ok sorted it ,turns out we had the amal valve and idle speed the wrong way round.
Cheers boys for the help much appreciated.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
muz
Sep 30, 2015 08:29 AM
