AP 362 brake kit...
Hi guys.
I hope that some of you can help me
. I have just fitted a 362 AP brake kit to my escos and my wheels are the AZEV type A 8,5x18 ET18, I was told when i bougt the brake kit that they would fit right on my car, but they dont, they are 14mm off. Now my question: Does there exist any kind of spacers and longer studs that are any good, so the driveabillity is not compromiced? 14mm is a huge spacer, or not???
Please help me
Jens henrik vinther (denmark)
Please help me
The best possible spacer would be HUBCENTRIC, they do solid cast spacers with all the trimmings, such as longer stud etc etc.
http://www.srbpower.com/hr/spacers.php
Oops hva Jens.. Den var da en kedeligt oplevelse
Det er godt nok osse et fyldigt bremsekit.
Har du rykket bremsekittet af igen sĺ, eller havde du andre hjul at montere??
Det er godt nok osse et fyldigt bremsekit.Har du rykket bremsekittet af igen sĺ, eller havde du andre hjul at montere??
nej bilen křre ikke om vinteren, men jeg skal da have fundet en lřsning pĺ problemet, hvis de kloge hoveder ikke mener at jeg skal křre med 20MM spacers i, jamen sĺ er jeg jo nřd til at ja mĺske křbe nogle nye fćlge. Men det ville jo vćre rigtig ćrgeligt for det er jo de fćlge jeg vil have ogsĺ er de kun knap et halv ĺr gamle. Hvis du evt kender en der er interesseret sĺ mĺ du endelig sige til
MVH.
jens henrik vinther
we had 356 ap 6pots with cp5555 calipers and avez A et 18 with no issues only moving balance weights close but was fine was a reyland/rainbird kit aswell no spacers whatsoever needed
What offset are the AZEVs, as I think you will struggle with arch clearance with 20mm spacers. The AZEVs are rubbish for clearance, and won't even clear 330 4-pots without spacers!
MVH.
jens henrik vinther
Der skal nok komme nogle gode rĺd herfra, thats for sure!! Og de er allerede igang
You could space everything inwards with new bells and rose jointed track rod ends but you will still be in trouble. Simple fix.. Change the wheels to the new 8.5" ET18 MO, they will fit then.
can't be good for the bearings?
