best tuning route for a zetec?
Old Jan 20, 2008 | 08:59 PM
Steve Rst's Avatar
Steve Rst
Default best tuning route for a zetec?
i building a replacement for my fiesta, and i've just bought a 2.0 zetec from a focus.
the engine is being mid mounted into a mini.
i was wondering what my options were for tuning it, and i have just a few questions!
the car will be on aftermarket management, as i dont want to mess around with an old loom. got a few ideas, but any suggestions would be welcome
obviously there's the turbo option, but i don't realy want too harsh a power delivery, as i dont want the car swapping ends permantly! but do roller bearing turbos provided a solution for this?
i was also seriously considering the powerworks supercharger option, has anyone had any experience of these? the dollar is weak as hell at the moment, so its getting cheaper all the time!
where in the engine to i need to concentrate? is there a specific weak link, or a certain part that restricts performance?
basically i dont want to be bolting bits on/in if i'm wasting my money, and should be heading in another direction!
any other input would be greatly appreciated.
steve
Old Jan 20, 2008 | 11:01 PM
zippyobrien's Avatar
zippyobrien
inlet manifold even using the rs1800 one restricts you to 150 bhp in naturaly asspirated form
Old Jan 21, 2008 | 09:08 AM
Steve Rst's Avatar
Steve Rst
oh, okay. so is the st170 inlet different then??
Old Jan 21, 2008 | 12:43 PM
JesseT's Avatar
JesseT
It's very different, it's a dual length runner type.
Old Jan 21, 2008 | 07:57 PM
Steve Rst's Avatar
Steve Rst
And it will fit okay?!
is that the main restriction to power upgrading?
after that i suppose its just a matter of going down the usual channels of headwork, cams, etc.
Old Jan 21, 2008 | 10:40 PM
zippyobrien
and management,
the maf sensor set up is limited,
alpha webber do a conversion for 1100 from burtons, takes you to 160 odd on standard inlet, so maybe bit more in st170
or just go for bike throttle bodies, or prover ones if you can afford them and megasquirt or gotec management,
then use either a tubular manifold or again an st170 one,
then head work and cams, need solid tappets if you going high revs, and they will need to be oversized if your going very high revs,
oil pump gears need changing for billit to
along with rods and pistons,
however, crank is good to 9k with arpbollts
Old Jan 22, 2008 | 03:52 AM
testastretta999's Avatar
testastretta999
Default Zetec
use Autronic ecu, scc had great results with it.
Old Jan 22, 2008 | 11:18 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
you deffo need throttle bodies for the breathing and after market management, set of decent cams and afocus st170 4-2-1 manifold.
should see near 200bhp
Old Jan 22, 2008 | 06:52 PM
Steve Rst's Avatar
Steve Rst
not sure if i can stretch to the throttle bodies! it will have to have a custom exhaust manifold anyway, being in the back.
what about these powerworks supercharger kits then?
they claim well over 200bhp, but how true is this? dollar is pretty weak at the moment!
Old Jan 22, 2008 | 10:26 PM
Phil2002's Avatar
Phil2002
Turbo it.
run it slighly higher compresssion and a small turbo will make it less laggy and should help to keep you pointing in the right direction as the power will come on a lot smoother and not so harsh as with bigger turbos.
Swap pistons for forged ones.
rods are good for 250bhp if you get them shot peened and arp bolts but rods from the ststes are cheap as fu*k at the mo.
meagsquirt managment on a fiesta turbo inlet with adaptor plate with beige injectors.
loads of fiesta stuff on ebay megasquirt cheap and loads of stuff for the zetec on the dedicated forums.
Old Jan 22, 2008 | 10:58 PM
Steve Rst's Avatar
Steve Rst
i do have a focus rs turbo unit around somewhere so thats and option i suppose. not sure bout the lag though!
any suggestions on where to get the rods? same with pistons aswell i suppose?
Old Jan 26, 2008 | 09:04 AM
testastretta999
Default Engine
Don't bother running supercharger, it costs you to power it from a pulley attatched to the crank.
Focus RS engine with take 390bhp on std internals (proven by scc)
I would like to see a bit more compression in a std motor, should be well responsive.
Rs focus turbo max 280bhp (genuine)
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
A.t.p
Sep 29, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
