Poorly Fiesta 96 1250 Any ideas?
Old Jan 19, 2008 | 06:10 PM
jbsportstech's Avatar
jbsportstech
Default Poorly Fiesta 96 1250 Any ideas?
Well I have bought a project car very cheap. Its a nice tidy 5dr fiesta with p/steering and the 1.25 16v lump. Its only done 70k and had fsh up to 51k. It had a new cat last jan and has only done 8k since.
The problem is it feels down on power very lumpy/hesitant and you ocassionally get some white smoke which only seems to come over 3.5, 4000rpm. I recon its valve stems or seals?
any ideas people
Old Jan 19, 2008 | 06:40 PM
dave green's Avatar
dave green
These engines dont normally suffer with valve stem oil seal problem like the CVH engine did, coil failure is very common
Dave
Old Jan 19, 2008 | 08:03 PM
Check your air filter and clean the MAF.
Old Jan 20, 2008 | 08:37 AM
jbsportstech
Ok I am going to do the plugs, Oil, Oil filter, Air filter anyway. Its has been sat up for abot 6 weeks but it hasnt got any worse on a 80 trip back down the motorway at 70-80.
I do think its the headgasket as it not eating coolant and there no bubbing in the header tank.
The air box was a abit dirty inside but the filter was not to bad (have seen worse) the MAF is the sensor monitoring the air flow by the airbox isnt it?
28
Sep 8, 2015 07:10 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Rizlablue
Sep 6, 2015 09:58 AM
Ben26
Sep 3, 2015 07:55 PM
