Escort Cosworth knock sensor
it depends if the program on the chip in the ecu is expecting to see one.
if not then it without one it will be ok. even if there was one fitted but the program didn't use the input from it it would make no difference.
Im going to be using a standard chip while I run the engine in - I take it a standard chip will expect there to be a knock sensor? Will it run ok without one?
Thanks
Thanks
jessie_rs
11
Jun 3, 2019 04:57 PM
