which way to richen with the c/o screw on a l6 cosworth ecu
Old Jan 18, 2008 | 07:15 PM
CozzyKing's Avatar
CozzyKing
Default which way to richen with the c/o screw on a l6 cosworth ecu
Hi all which way do you turn the c/o screw on the cosworth ecu to richen or lean the mixture at idle?
can't remember
Old Jan 19, 2008 | 08:07 PM
Clockwise to WEAKEN, anti clockwise to RICHEN.
Old Jan 20, 2008 | 08:25 PM
CozzyKing's Avatar
CozzyKing
cheers, much apreciated.
Old Jan 21, 2008 | 05:56 AM
That's ok, had to take me panel off the dash to check!!
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
James Porter
Aug 14, 2015 12:43 PM
Aug 14, 2015 07:29 AM
