My fiesta turbo
After a bit of info after owning a few erst's ive recently purchased a frst it has got a standard engine i have carried out the t3 conversion with a -31 actuator, added a green air filter and a magnex exhaust and it has a chipped ecu fitted. Im fitting a piper285t2 cam to it and beige injectors is this a decent set-up? what sort of return should i see on this when i get it set-up correctly?
the piper285t2 cam and beige injector and t3 its all good, thats wat i have on mine, but mine is a 1.9cvh and it is pumping out between 200 and 220. dont know wat the 1.6 cvh should see though.
wat boost is it running and wat chip is in it??
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
