Morette twin headlight wiring
Old Jan 16, 2008 | 06:05 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Default Morette twin headlight wiring
Guys
Ive recently got a second hand set of Morette twin headlight conversion with wiring loom and a relay, ive just had them painted and now want to fit them this week end.
Is it just a case of plug and play, or is major wiring needed?
Can anyone shed a little light on how to do this or has anyone got a wiring diagram?
Thanks
Old Jan 16, 2008 | 06:44 PM
ECOS95's Avatar
ECOS95
Its straight forward. The existing headlight connectors plug in to the Morettes. You also need to connect an earth on the drivers side headlight & the connections for the relay on the passenger side to the battery.
Thats about it from what i remember.
Old Jan 17, 2008 | 12:57 PM
dan le moignan's Avatar
dan le moignan
yea sorry Steve should have done a diagram when i removed them! as above, they plug into the std escos plugs, then its just a case of finding a place for the 1 or 2 earths, and running the live upto the battery
Old Jan 17, 2008 | 01:07 PM
Steve the Plumber
Thanks guys.
Old Jan 17, 2008 | 02:55 PM
ECOS95's Avatar
ECOS95
The instructions that come with them are translated from French to english & take some understanding. Makes you scatch your head for a bit.
Old Jan 19, 2008 | 07:55 PM
Steve the Plumber
All done now, it is plug and play, but with 2 earths and 1 live connected to the battery with a in line fuse.
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
mondeomark
Sep 28, 2015 06:28 AM
