OFAB, first start no spark
Old Jan 13, 2008 | 08:03 PM
mudgey's Avatar
mudgey
Default OFAB, first start no spark
Hey guys, got my wiring harness back today, all the continuity on the wires seem fine. When the ignition is turned i get the clicks from the relays and the pump powers on, then powers off until the engine is cranked. It smells like there is fuel being pushed through the injectors (thou havent checked properly yet). but i have no spark.
What are the common causes of no spark? Hopefully there is something simple i can check incase it is that!
Will it not spark if the voltage drops below a certain amount? The engine will crank over but rather slowly tbh as the batt hasnt been charged in a few months.
Thanks in advance!
Regards, Mudge
Old Jan 14, 2008 | 12:08 PM
If it's crancking over you have enoguh power for sparks.
I would recheck connections again first.
Old Jan 14, 2008 | 06:01 PM
mudgey's Avatar
mudgey
Hey, i checked the connections, all seems fine apart from 2 pins on the EDIS module that dont seem to lead anywhere! Does that sound right?
Old Jan 14, 2008 | 07:48 PM
mudgey's Avatar
mudgey
Hey guys, quick update.
The injectors fire when it is cranked so that shows that the CPS is working. I replaced the EDIS module and still no luck. There is no spark on any of the cylinders, so must it be a wiring fault??
What do i need to check next??
Many thanks, Mudgey
Old Jan 14, 2008 | 08:39 PM
mudgey's Avatar
mudgey
another update, i see the coil isnt getting any power, its got an earth, a line to the EDIS module but no power?? I tried hooking up a power to it and it sparked. I take it thats not right then??
What can i do now?
Mudgey
Old Jan 15, 2008 | 07:25 PM
mudgey's Avatar
mudgey
Hey guys, any ideas on what i can do? I'm really stuck and its a nats bollocks hair away from startin, is well irritating!!! hehe
Regards, Mudgey
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
