project 4wd 400bhp 1.5 LOADS OF PICS
UPDATE AT BOTTOM OF PAGE
been looking on here for a while now and thought i would put a few pics of my project i am doing at the minute,
bought a 4wd starlet of ebay for 640 quid with plans to strip it all back and make it a gt replica but going fully forged and 1.5 block and using the td05 i have
i swapped my white gt which was td04 lsd etc with a mate for his not so good looking gt
then started stripping and swapping everything over
engine out
dash and loom out of car
gearbox all cleaned down and painted
front bumper all cut out
5efe engine
inlet given a quick clean up
engine bay rubbed down and sprayed black
bit more work done today, complete loom swapped over, steering rack, brake servo, master cylinder, clutch cyclinder, pedals all conected back up, steering coloum swapped over, fuel lines had to be cut and joined as the gt has different fuel filter connector, brake lines put in, gt calipers, disc and stering rack fitted to hub and wishbone, heater and air con all removed fron inside dash, as the wiring is different, power steering fitted
the colour i am after
dash and complete loom in and working
got a few pics and parts, BIG intercooler 34 inch wide, front and rear anti roll bar's will have to modify the back one to fit as the diff is in the way, trd engine mounts, toby's catch can, apexi avcr, loads of intercooler piping, anyone got any links on wiring in the avcr
got 5e engine completely stripped down and done a few more photoshop's
cleaned and polished out the head too
carpet been taken out and floor all primed up and resprayed black, and I have ordered TURBO:rockon:
this the turbo i pick up on monday .63 hot side and the 4" anti suge
engine out
5efe engine
dont feel too bad about the drive system as is is 4wd or is it awd?
the difference is 4wd is not always on( like skylines GTR'S) while awd is always activated ( like evos)
honda make a 4wd wagon version of their civic that comes with less than 130hp and even though a lot of people slated it it has been used on honda D16s producing around 400hp
here is the link:http://www.honda-tech.com/zerothread?id=2104408&page=1
plus there are videos that show how it hooks up on launch
also for the avcr wiring go here http://apexi-usa.com/support_wiring.asp
but people have issues setting up gear based boost even using the manual
so go here for that http://www.honda-tech.com/zerothread?id=1037051
hope that helps mate
got car back from bodyshop. smoothed in petrol cap.airiel (sp) and rear boot lock and wiper
and picked up a few other little bit's external fuel pump, air filter and wastegate
wastegate and external fuel pump
Quality project, love the colour
