fuel pipe help
Old Jan 10, 2008 | 09:55 AM
coswurv's Avatar
coswurv
Default fuel pipe help
as some of you might know i have a resto thread on here and i need some advice on fuel pipe, basically the pump end is ok but follow the feed on from that it goes through your standard metal fuel pipe under the car and comes out in the engine bay, i need to connect to that blank metal end to some high pressure hose i take it then onto the 2wd cossie fuel rail, what can i use ?, i know i could weld a aeroquip union into the fuel rail but its the fuel pipe stump i dont know what to connect to that, any info or pics much appreciated.
155lee
Sep 6, 2016 11:10 AM
steve.rst
Mar 15, 2016 08:01 AM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
