EscortRSCosworth.com Login probs
Hi guys I have finally got the log in problems sorted.... I think
If you are still having log in problems it is probably because the cookies have now changed and you will need to delete them and refresh the cache.. To get the new correct settings.
I need to monitor whether the fix has worked so can you please log in (if you can) tick the keep me logged in box.. close the browser and open escortrscosworth.com again and see if your still logged in and let me know please
Sorry for the problems guys
Apparently the log in issue is a known fault with the PHPBB3 forum
Loads of PHPBB usres are having the same problems and the makers are working on it. If it doesn't get sorted soon I'll fuck it off and swap to a different forum like V-bulletin. Prob is where as PHPBB3 is free, V-bulletin is about £150
I may do this anyway as it seems a little unrelible and the forum seems to be taking off
